I can successfully call a point detail on any of my TPS points on the Experion display. I can even use those points in Quick Builder to create PV Algo with these values.
But I can't work out how to PUSH a value down to the TPS point.
I followed the section 11.10 'Attaching algorithms to TPS Points' with no luck. Apparently you create a Quick Builder point, and set the PV Source to the TPS point. Then you set a PV Algo, and configure. Apparently, the PV Algo should update the PV Source - and thus the TPS point.
Any thoughts?
Any thoughts?
