Hi all
I got 4 identical 650KVA Gensets that uses ESD5500E as the speed controller. The device has a remote speed adjust input that comes as a potentiometer (Resistance), am using the DeepSea 8610 controllers for this job to synchronize the sets, this device has a analog output for the governor that provides 10 +- VDC, is there a way to convert this voltage signal to resistance in order to be able to connect it to the speed governor controller (ESD5500E) ?
Thanks in advance guys
