We have a rural site that is having intermittent problems with the remote I/O. We have worked through all of the possible network problems and now suspect that the power may be the culprit. I would appreciate it if someone could recommend a vendor or device that could monitor the incoming 120VAC and outgoing 24VDC power. The device will need to log several hours of data as it will be a while before we could get to it to retrieve it.
The power supply we will be monitoring is an AB 1606-XLS120E. Not sure if this relevant but thought the question might be asked.
