Greetings,
I have a customer who had been using a 12-24 VDC power supply to power our wall mount Co2 sensor for a 0-5 VDC out put to their controller. Their controller is a Microzone II that uses 24 VAC to be powered. They kept popping the circuit breaker back at the panel, then they changed to a different power supply that was 12-24 VAC and all was well.
My question is this, I thought most controllers have bridge rectifiers built into the analog inputs, so you could connect a sensor device wich is being powered by either DC or AC? Keep in mind this Microzone does not source power you have to provide it as an external power supply.
