In a gas turbine PG9371 FB Simple-cycle single-shaft heavy-duty gas turbine at a speed of 1006 rpm for two measures the peaks and bb2 bb2X probes and vibrations occurring in the bearing 2 (bearing 1 GT) 0.18 mm/s, trip unit to the value of 0.22 mm/s. the second peak at 827 rpm with the flame off to 784 rpm.
At startup high vibrations also occur at 996 rpm, coinciding with the point of passage through the critical speed when starting and stopping the unit.
What could be causing this increase vibration values to the trip of the unit?
