GE 9FA gas turbine, there was a problem in the
hydraulic/lift pump that it didn't give sufficient lift pressure to permit Turning Gear to run, so the lagging pump was forced to run. noticed that after reaching 3000 rpm couldn't make Auto-sync unless lagging pump was turned off.
the question is: what is the relation between Auto synchronization permissives and operating with both hydraulic oil pump?
