We have an number of open vessels, steam jacketed, with a thermowell with Pt100 at the bottom. There is no "cavity" in the jacket to place a flanged thermowell. The stem of the thermowell is welded on the inside of the vessel and on the outside of the jacket. (for as far as I can see.) length in the vessel is approx 4 inch.
Now when we measure the temperature with a hand probe at the surface of the mixture (being well mixtured), there is always a few centigrades difference with the Pt100 display. Could the reason be this type of thermowell installation or ????
On the www, I can't find any info of proper installment of thermowells in jacketed vessels so if someone could help me.
Thank you
Thank you
