Hi everyone
I'm working now on a GE frame9 gas turbine. when I was reviewing the atomizing air diagram in P&ID I noticed an odd thing (for me!). Output of atomizing air compressor goes straightly to atomizing air manifold(without any valve or checkvalve or ...)
Now I have a question: consider the unit is working with liquid fuel and we change the fuel to gas. VA18 will open, and a portion of air will recirculate through atomizing compressor. VA19 will open and a portion of air will go for purging the liquid fuel path, but what will happen for the air which enters the atomizing manifold or even is there any air flow to atomizing manifold? If yes would it cause some problem for firing in combustion chambers? if not how it is possible with considering there is no valve, checkvalve, ... in the path?
I'll be glad for any answer.
