O
We had a compressor failure in 2013 and had to carry out an unplanned major inspection to replace compressor. Initial startup with new compressor gave a CPD or 10.4 bar. However Initial startup of same unit with an old compressor in 2010 gave a CPD of 10.7 bar after major inspection when the compressor was steam washed.
We suspect bleed valves not sitting properly. What ways can be verify
the integrity of the bleed valves online?
Are there any other causes of this CPD performance degradation?
