Hi Everybody
Synch Gen can produce positive Mvar or use negative Mvar. What's AVR rule in this process? I mean after Gen connected to grid Gen terminal voltage is as same as grid voltage. Is this correct? In some references it mentioned that Gen terminal voltage as Pu for example is more than grid voltage so Gen produce Positive Mvar and if Gen terminal voltage be lower than grid it uses Negative Mvar. I have some questions here, please see:
http://hemmati65shabakeh.persianblog.ir/page/5)
1-Is Generator terminal voltage differ from Grid voltage after Gen is paralleled by Grid? why is it more than voltage grid?
2- What is AVR Drop and what happen in AVR that it causes Positive and Negetive Mvar? I mean MVAR is negative and using AVR we change it to 0 or Positive Mvar. I want to know how Avr do this exactly. You may say by changing PF form lag to lead or reverse. I want to know the mathematical relation of this changing or control loop of this process (Controllers, Electronic circuits,...)
3-We say Synch Gen Produce or use Mvar. How do physically the Gen do this? What happens that Gen produce or use MVAR as Capacitors or reactors? What do AVR over Excitation or Under Excitation mean and what are their rules in Mvar production and using?
I would be pleased if help me using mathematical relations of these process or introduce strong references in this field.
Best Regards
[email protected]
Best Regards
[email protected]
