E stops
E
engineer1000
Hi
I need to wire up some e stops together. I need 2 core cable. what type of cable should I use? I've tried Googling it but can't find any thing.
E-Stops have no unusual cabling needs. Just select based on circuit voltage and overcurrent protection size. The only out-of-the-ordinary feature that might be justified might be armored cable if it's exposed anywhere, to prevent mechanical damage which would create avoidable equipment downtime.
