The Parameters I have to set are:
Setpoint [Uint16]
Actual Values [Uint16]
Bit Values: for example "PowerSupply ON", "Reset", ... as only one Bit or as an Word value.
I see that there are four basic data references 0xxxx, ....4xxxx.
But if I want to write for example a setpoint or PowerSupply ON command, which address I should use for these values?<pre>
Setpoint: Function Code: 06 Address 40001? or 0001?
PowerSupply ON: Function Code: 05 Address 00001?
PowerSupply ON + Reset in a word value:
Function Code: 15 Address 00001?</pre>
Thanks a lot for helpful information.
Setpoint [Uint16]
