Looking to see if there exists a solenoid valve with a third wire that senses the valve is closed when power is off. Does this exist?
The need is to signal another control outside of the subsystem to shut down if the inner system solenoid fails. The idea is that the always on status has caused some level of corrosion or other effect on the actuator so it will not close properly.
