Hi to all,
I have few questions about 6fa which Follows,
1.At what RPM of the turbine, starting Mean disengage from the turbine shaft. (we use electric mean starting system with voith coupling and Natural gas used as fuel)?
2.At what rpm purge done?
3.At what rpm firing done?
4.At what RPM Warmup done? and warmup estimate time?
5.at what Rpm acceleration starts?
6.if flame establish fail while startup, is the turbine reduced its speed to cranking speed?
7.on what basis fuel stroke reference for all the gas valves is set while starting the turbine or FSR is CONSTANT?
at last 8. why 100.3% speed at fsnl????????
Great minded peoples, Please do reply as easy...bliss to see.....
thanks and Regards....
