HELLO ,
Need a detailed reply of manual checking of Electro hydraulic servo valves of gas splitter valve. Recently our frame tripped due to Split valve problem, after that we changed the valve for that. but how we check the servo valve working correctly before the unit startup?
is there any way to do this through Mark v system HMI<I>?
and in trip log I saw one header with the name DROP NUMBER. what is the use of that number?
kindly reply folks..
thanks and regards
thanks and regards
