I
We have upgraded the control system from Mark 2 to Mark 6e with frame 5b machine. We want to know the procedure to calibrate liquid fuel valve in frame 5b machine where there is no aux hyd oil pump. We went up to cranking speed and forced l4_xtp to false and l20flx1 to true, the turbine tripped. We repeated, but it happened to be the same. How to build up the pressure and proceed for calibration? I went through some threads but did not get the actual thing i wanted. In some thread it was given that give fire with ignitors off, but it will give fail to ignite and trip or come to crank speed.
Please help us with some procedure or ideas.
