Dear ALL,
I have a small query regarding alternator as follows,
If the alternator Produce 50mw (rated load) with 2 poles in 50hz frequency at 3000rpm coupled with gas or steam turbine.
is it possible to change the 2 poles to 4 poles alternator (same rated as 2 poles load), for the same 50hz frequency with 1500rpm (rotational power) from the same turbine with reduction gear?
kindly reply...
kindly reply...
