Recently during Steam turbine shutdown, we got in trouble when the AOP tripped. One of the lugs at the terminal had overheated due to lose connection (most probably). The EOP could not sustain barring as the discharge pressure was 1.9kg/cm2. There is an interlock of pressure to be more than 2.5kg/cm2.
Then the pressure interlock was looped and barring was started with EOP till AOP was normalized.
I look after gas turbine operation. My question is what best option we have in case ratchet motor fails (for any reason) during shutdown?
Or at any time during cooldown?
Can we have a standby ratchet motor?
Is providing as airtight closed compartment as possible an option so that the heat does not escape?
