Gas Turbine VS Gas Combustion Engine
Diaa
which is more responsive to the continuous fast load fluctuations (0-250KW/sec) the gas turbine or the gas reciprocating engine with the same power rating (1500KVA)?and what is the effect of the fluctuation on both of them?
Is there a minimum load so the gas turbine can run?
Is there any standard talks about this subject?
Thank You
combustion reciprocation engine can not operate with direct coupling in sync with a grid/other generators. In between a fluid coupling is normally engaged this will cause higher loss.
Gas turbine can be directly coupled and synced with grid/other generators so coupling loss will be less.
For standalone system reciprocation engine is preferred for ease of availability and construction and efficiency.
If some one can enlighten more on this, please response.
