My late husband connected the Control & Readout Ltd 406 Controller via a cable to a small toaster oven, so I could obtain an accurate controllable temperature, but the plug and socket from the controller got disconnected during change of room, and I am unsure of how to re-connect. There is a short white cable coming from the controller with a 3 pin rubber socket on the end, there is also a black cable coming from the controller with a 3 pin mains plug on the end. Could anyone tell me how to connect the controller up again. A diagram would be appreciated.
Thank you.
<b>Moderator's Note</b> Yes, I know this is not about automation or manufacturing. But can any of you help this woman out?
Thank you.
