Hello guys,
I have problem with communication Modbus RTU, for those moment we still in engineering and construction phase for oleo chemicals plant.
We have idea to use Modbus RTU with RS485 serial communication line for load-shedding system in power generation. We have Power logic control in each of Low / High Voltage panel, and I was try to communicate between subsystem (Power logic metering Schneider PM5035 and main system DCS Yokogawa Centum VP on (IFAT-integration test), and no issue. But I have worry, because actually we have a lot subsystem on the site include PLC (modicon). Could somebody tell me know to calculate the response time (bidirectional) let say the data is 100byte/ subsystem & speed is 19600kbs, how to calculate if.
1. Single subsystem connected.
2. Multi drop point with multi subsystem connected.
Thanks and regards,
Abraham Februano
[email protected]
Thanks and regards,
Abraham Februano
[email protected]
