T
Product: STEP7 Professional V13
Reference: FB Declaration Static: Data type TON is not allowed here
Description:
I'm using Step7 Prof V13 SP1 upd7 & WinCC Adv V13 SP1 upd7.
In my project I'm using a 312CPU, Article No.: 6ES7 312-1AE14-0AB0, Version: V3.3 & TP1500 Comfort, Article No.:6AV2 124-0QC02-0AX0, Version:13.0.1.0
My Issue:
I've taken previously used FB from my Global library and inserted it into my new Project. In this FB I've declared an IEC Timer (TON) in the static section of the FB. When I go to upload to the PLC afterTIA carries out the compilation I get error message 'Data type TON is not allowed here'. I've tried creating a new FB to test and had same issue for CTU,CTD,TOF.
Unfortunately I can't upload screenshots to this forum so hope its clear what the issue is.
This is really strange as it has always functioned before! Has anyone seen or heard of this issue before?
I'd appreciate any help, Cheers.
<b>Moderator's Note:</b> you can use a public share site like Dropbox to post screen shots.
Description:
My Issue:
