H
Hi all,
I have few queries related to MarkV logic modification and CSP.PRN file
1. How to modify the logic in the CSP.PRN file. Suppose if i want to add any NO/NC contact or any block, how can i add it?
2. Can anyone share the example CSP.PRN file of two GTs and two STs running in isochornous or droop mode ( one pair in droop and other pair in isochronous monitoring each others status) and the functionality is controlled by master controller?
3. How to convert the CSP.PRN file into the PDF document? So that it is in more readable format?
4. i have read that adding IO to QD core means TMR, but adding IO to CD core is simplex. Can anyone explain how?
Has100
Has100
