G
Hi guys,
Is it possible for a genset that is parallel with utility power factor to decrease for .94 to .60 with causing a rise in the system voltage? The power plant consist of diesel genset operating in share (isochronous) and base load. The genset in share load is in voltage control an genset in baseload is in Pf control. The utility total load is 25 MW.
