Plant Status before Incident:
1. GT-1&2 were in Service with total 12.5 MW load. GT-1 @ each at 6MW each. GT @ 6.5MW.
2. GT-1 on liquid fuel and fuel transfer from liquid fuel to gas fuel was initiated as part of the GT-1 reliability test.
Plant status after incident:
1. GT1 load reduced to 6.0MW & fuel changeover initiated to gas fuel. GT1 tripped at 16:48 with following alarms:
"PT output bearing vibration high"
"GG axial displacement high"
"GT trip adjacent thermocouples failed deviating".
2. GT-2 load shoot up from 6MW to 12.2MW as load shedding not acted and GT tripped on
"GT trip turbine limiting temperature high."
3. Black out at Power plant due to both GTs tripping, EDG took auto start.
4. GT MCC loads were manually normalized to prevent EDG tripping.
5. GT-2 was started, but stopped at 17:47 hrs.as lub oil piping was vibrating heavily.
6. GT1 started & failed on GT start abort can flame failure tip temperature failed/deviating.
7. CPF-2 East substation power supply extended from RPP as Power plant GTs start up deferred.
