W
Dear All,
we just completed our CI on GT frame 9, and unfortunately the generator been replaced with standby unit from other power plant due to internal shorting. Our existing generator is 120MW and the replacement generator is 108MW and we were using our existing excitation system. Our maximum load before this is 97MW but after the replacement we only got 94MW, with excitation parameter still below alarm and no indication excitation limit has been reached. is there any setting need to be on on the excitation or control system mark V regarding load angle or anything? We checked all the condition on the turbine/mechanical side so far we not fine anything abnormal.
regards
William
regards
William
