N
I'm putting an installation detail together for a GE ultrasonic GF868 gas flowmeter and I have a simple question. There is an analog output board (4 loops) where I need to connect to a weight, pressure, temperature and flow transmitter. The terminals are marked signal and return. Where do I connect my black (+24vdc) and white instrument wires at the board and at the transmitter? Also, if there is a good website for this kind of information, would be helpful.
Thank you in advance.
David
David
