I want to use the output of current transformer as input of PLC, by converting it to 4 to 20mA. I have not the exact circuit which an convert the CT output in 4 to 20mA.
There are CTs with the 4-20 conversion built in, or if you don't want to use those, or already have standard 0-5A CTs, you can buy signal conditioners that will do the translation.
I think there may even be 0-5A PLC analog input modules.
Thanks sir for reply.
I am a student of Electric Engg. I am making a project in which I need this transducer. I do not want to buy this module. I want to get only exact circuit diagram and I will make the hardware myself.
