I know that speed droop mode can be used in mains parallel operation. Need all droop setting the same? the droop setting normally around 3~5%. how it possible to the droop setting the same around the world.
I’m lost with this speed droop. | Power Generation | 8 | ||
Droop speed control | Power Generation | 9 | ||
O | Droop Speed in 9E GTs | Power Generation | 4 | |
A | Turbine Speed Variation in droop mode | General Automation Chat | 3 | |
A | KW mode, Droop mode, and speed mode | Power Generation | 0 |
