L
We have purchased several manifolds from an instrument vendor and during our full range pressure testing we have found a portion of them begin to leak out the handle of the process isolation valve. When the leak occurs it is a definite cracking sound at higher pressures (3500-4500psig) and the first drop of water is milky white, then they run clear from the water in the pressure tester. Any ideas on what is failing? It seems to me it is a supplier quality issue and the vendor should be testing their products across the full rated range. (These manifolds are rated up to 5000psig)
