G
I am renting a wood drying kiln at someone's machine shop location. He wants to charge me for the power usage for the kiln. the kiln has 3 heaters connected in delta and they are supplied 3 phase electricity. I have to pay him, but I do not how much energy is used.
I know the line amps and line voltage, but nothing else. The load is a resistive load. All three phases have 13 amperes load. Two line voltages are 120 volts at 180 degrees phase difference. Third line voltage is 240 volts at 90 degrees phase difference to each of the other two voltages. I would like to have the formula to calculate power for such unbalanced circuit.
Please help me if it is possible for you to do that.
Best regards,
Gulab Gidwani
[email protected]
Best regards,
Gulab Gidwani
[email protected]
