Dear All,
I want to ask about adding totalizer for Gas Flow Metering in MarkV Panel A. Last time I added totalizer in TOTT_Q.SRC like this:<pre>
3 FQG 512</pre>
It works, but it only works for English scale (Lb/s). How can I make it for Metric Scale (kg/s)? The result is 360 with FQG +/- 2,75 kg/s or 6,1 lb/s.
FYI, the max scale of lb/s is 64 and for metric scale is 29.9.
And also I tried it in Mark V Panel HB with the same format and it won't work. Any Ideas?
Thanks Before,
Best regards
3 FQG 512</pre>
Thanks Before,
Best regards
