I need help with the relays of the serie SR3 Multilin.
These relays have the following configuration for Ethernet communication:
Ethernet IP Address:
Ethernet Subnet Mask:
Ethernet Gateway Address:
Ethernet Connection Type: Copper or Fiber.
When communication settings are placed to the relay, for example:
Ethernet IP Address: 168.32.34.123
Ethernet Subnet Mask: 255.255.230.0
Ethernet Connection Type: Copper.
and connect the relay to the net, there is no master's in communication with the relay. the led "Trouble" becomes active and generate events "High Enet Traffic".
How the communications of the relay can be configured that relay not generate "High Enet Traffic's" events?
Where is the problem?
In the following link to the page of the manufacturer can get discharged the software and the relay manual, for better information.
http://www.gegridsolutions.com/multilin/catalog/339.htm
