I am writing a column on Remote Access methods, concerns, and options.
Is Teamviewer, LogMeIn, VNC, and RDP 'good enough'??
Is using a remote laptop and a VPN with a password good enough?
Is there any need to authenticate the device or user that is logging into the network?
Is/are the process(es) that is/are available to the network critical enough to require a higher remote access security requirement than 'normal', or do we simply not care?
Thank you in advance for any and all replies!!! Much Appreciated
Cheers from: Jeremy Pollard, CET The Caring Canuckian!
Crisis, necessity, change
www (dot) tsuonline.com
Control Design www (dot) controldesignmag.com
Manufacturing Automation www (dot) automationmag.com
