In our gas turbine power plant, fumes always come from the mist eliminator vent. So much that the surrounding area becomes slippery.
The vacuum maintained is around -100mmH2O. The problem with lower vacuum is that lube oil leakage starts from load gear and other points.
Can there be any balancing method to prevent the fumes and leakage both?
Is there any safe method in use anywhere to discharge the fumes?
