Dear Sirs,
we are running a simple cycle GT-Fr9 on crude oil. one of the units started to trip by "high exhaust spread", our mechanical department used "SWIRL" program to identify affecting cans. they replaced 3 fuel check valves. we ran the unit again but same problem happened then they replaced 4 check valves, and we start the unit again but the same trip happened.
After each start-up, SP1 started to increase firstly at high load (95MW). then after like 90 minutes the same value of SP1 recorded but at lower load (85MW). by counting operational hours the occurrence of the same value of SP1 keeps to happened but at lower loads up to (60) MW.
QUESTIONS:
1- why SP1 value started to be high at high load (our case 95MW/sp1=52) then the same 52 happened at 85MW then after hours the same 52 happened at 60MW.
2- what are the possible causes of high spread?
3- is the value of SP1 that matters? or is it the difference between SP1 and allowable spread that matters?
QUESTIONS:
