Hello Genius peoples,
Hope you're fine...
TURBINE SPECIFICATION:
GE 6-FA,MARK V,DLN 2 SYSTEM,LNG fired plant.
Now come to the problem...yesterday while starting our GT, The SRV valve starts Hunting, (NOTE - Other control valves primary, secondary, spliter valve are normal-GE make with MOOG valve control) But GT goes upto FSNL with SRV hunting continues. we check the hydraulic pressure are normal and its auxiliaries such as accumulator at normal condition. At last we found that some seal leakage problem in the actuator of SRV (Which is GE make with Moog control.
So we decided to change the actuator of SRV With another actuator (get spare from nearby plant) which is moog make actuator with moog control valve itself.
The question is our nearby plant is used same 6fa turbine with MNQC combustion System. Can we use that moog actuator for our DLN system?
thanks and regards,
Hope you're fine...
thanks and regards,
