The Answer is Yes. But there is a catch to it based on application. PLCs are designed for more rugged industrial use. That is for continuous operation. It will only have a specific set of inputs, outputs or logic possible. On the other hand, micro controllers would have the advantage of programming more sophisticated logic, but reliability and Real-Time operation are factors you may have to consider.
With appropriate hardware, systems using both do exist and can be designed.
