Has anyone encountered a situation where the 3 pressure transmitters for the Mark VI SRV/GCV system sends the wrong pressure to the HMI, but on the field, the gas skid pressure, the srv/gcv pressure and the intervalve pressures correspond in operation.
Note: The pressure transmitter has been changed and certified ok
The voltage level that was measured at the vme card termination in the LIOS panel indicates that the transmitters are send signal to the mark vi ,but not corresponding with the right pressure.
