We have rosemount 3051 dp cells ranged 0 mbar to 125 mbar. These are smart transmitters so only the hart values are used. I been looking through previous test sheets and these have sometimes failed their calibration. It was noted that that a zero adjustment was done or a zero and span adjustment was done. What exactly did they do? Do they do a zero trim for the zero adjustment applying 0 mbar and for span a low and high trim. Low trim applying 0 mbar then applying 125 mbar for high trim? Am a bit puzzled whether to use the zero trim or low trim if the zero is slightly high.
