U
We are facing a DC supply problem at our power plant. The DC power of turbine control panel and generator relay panel is going and coming back within a split second which is causing the turbine to trip. We then provided the dc source from a different battery charger and changed the cables.Five days later the same thing again. We have checked the voltages, connection tightening, any looseness or cuts in the wires of the DC circuitry, IR test of cables but all were found good. Even the individual mcbs are not tripping neither the incomer mcb. Everyone is just going nuts. Has anyone ever faced this type of problem?? Any sort of information or help regarding this will be highly appreciated.
