Today we released a FREE AB DF1 serial slave simulator. All of our simulators are freeware.
File types supported
Input, Output, Status, Binary, Timer, Counter, Control, Integer, Floating point, ASCII, BCD, Block-transfer, Message, PID, SFC status, ASCII string
File numbers 0-999
Logical binary addressing is supported.
Command/functions supported<pre>
CMD Function Name
$0F $00 word range write
$0F $01 word range read
$0F $26 read modify write
$0F $A2 protected typed logical read with
three address fields
$0F $AA protected typed logical write with
$0F $AB protected typed logical write with mask</pre>
Notes:
1) Message file data, zero (0) is returned for all internal/reserved memory for each element.
2) PID file data, zero (0) is returned for all words of each element.
3) Read-Modify-Write, single word only.
If you need any help/find a problem/request an addition or change, contact us using our support email address (in the About dialog).
Here is the link to the installer: http://www.hmisys.com/downloads/PeakHMISlaveSimulatorInstall.exe
Good luck,
Mark
http://www.peakhmi.com/
File numbers 0-999
CMD Function Name
Notes:
Good luck,
Mark
