Dear friends;
Good day. I read that For the tilt pad bearings if oil pressure is low and the oil flow is high there is a sealing problem in gas turbine. What phenomena behind this?
We have four tilt pad bearings in a gas turbine model Centaur 4702. each bearing have 6 pads.
I hope you will favor me on this subject.
Thanking you i will remain.
