Hey,
i have a GUTOR UPS including 2 inverters and one bypass for them. i replace a fuse that blown before which located before static switch of the inverter. after we re-operated that inverter by the recommendation steps, explosion was occurred and the snubber across inverter static switch was burnt. after that we made a continuity test on all equipments and no problems noticed.
can you give me an approaching solution about this problem?
thanks alot..
thanks alot..
