Gas Turbine Frame 6b (Mark VI), I came across a Flow transmitter with P4 (flow rate) of 0 to 15000. Yet to confirm the unit with an hart communicator, I am guessing litres per min or lbs per min. The Mark VI Toolbox software config unit is in gallons per min and on the HMI data (FQG) is in Litres/min. The software configs low value and high value is -25 to 3200 gpm (4mA to 20mA) respectively.
Kindly advise on similar cases
