I have few questions on Governor control:
1. Whether the isochronous and droop speed control are default features of all governors, both electronic and electro mechanical?
2. I presume the automatic switching over from one mode to another is effected by the utility grid circuit breaker status during islanding and grid parallel operation of the generator. However, when multiple generators are in parallel operation,which generator is selected for isochronous operation, when separated from grid?
3.Is it a must a load sharing system is incorporated for multiple generator operation for smooth running on islanding & grid parallel?
3.When an external load sharing system in place, whether all the generators will be operated in isochronous load sharing or droop speed control load sharing by the controllers?
4.Finally,how much effective the external load sharing system will be for steam turbine generators?
Please bear with me for too many questions.
Thanks.
Thanks.
