I have 3 questions regarding gas turbine operation.
We have gas turbines running in Liq. as well as gas fuel.
When Gas turbine runs in Gas fuel, the liquid fuel nozzle is purged with the Atomising air continuously via the VA-19 pneumatic valve. At the same time the AA manifold also receives AA. In a way the AA line of the nozzle is also purged.
Why is continuous purging needed for nozzles? A maintenance person told me that in some system, the VA-19 valve is opened only for some seconds after fuel changeover to Gas from liquid fuel. Is that right?
What is the significance of Machine tripping in Low AA compressor differential pressure (actuated by pressure switch 63-AD across the AA compressor). Does that has anything to do with the purging of the nozzles?
Why should the liq fuel atomising air pressure be greater than CPD?
