on Mark-VI simulator, whenever I configure alarms through Toolbox and propagate the same to HMI (though PUT Into and GET from - as per the procedure as per GE's instructions), we are facing issues with HMI Operator screen. The alarm function however works alright, meaning - alarm appears on HMI screen up on simulation (by forcing relevant logic signal). But, we face the following issues.
1. The MODE commands (Crank / Fire / Auto) go ineffective. In the sense, the confirmation window pops up on clicking on these commands, but the command doesn't get executed.
2. Sometimes these commands are active, but I will not be able to start the unit, as the FSR manual automatically gags to 0% and that we get an alarm "Emergency Oil pump could not be tested".
Has anyone had similar experience with Mark-VI simulator? Appreciate your time in addressing this issue.
