O
Pls I need help with troubleshooting an issue on GE MK VI. There are certain alarms that are active and holding the unit from getting to Ready to Start. These alarms are:....
Checks show that those alarms are from instruments and signals connected to TBCI 1E1 & 2E1 terminal cards. These terminal card J cables J44 and J33 are now connected to VCRC slot 8 TMR.
Checking the diagnostics alarms on the VCRC shows the following alarm: "Excitation voltage not valid, Contact inputs not valid"
We changed the terminal cards from another unit dat has been out of service but the situation hasn't changed.
Pls what do you think is the cause of that Diagnostic alarm on the VCRC and the many annunciated alarms coming from the 1E1 & 2E1 terminated signals? Can someone pls advise on the solution that can be used in this situation.
Thank you in anticipation.
