Hi All,
Following an oil leak with no ratcheting when coming off load and 3 hrs oil circulation, machine came back with minimal vibrations. however after a few hours running, tripped on high lube oil temp on load gearbox. Any ideas?
I've been assured that the oil is the same spec, but this was my first suspicion - seems unlikely to me that any gearbox damage has occurred while all the bearings temperatures are ok. Declared available at 32MW instead of normal 42MW to allow continuous running without hitting limit. Thanks for any advice.
David
David
